Auto Cooler Upgrade
Hi can anyone here point me to where the original autocooler is on my jap TT?
I have a british oil cooler wich i want to swap over, so any other parts i may require would be a help also.
Thanks :p
Hi Steve
ย
The original one is inside the radiator not sure what is required to fit an upgraded one
ย
Eddie
Thanks Eddie im going to do a full 60k service soon so ill check it out then.
Im hopeing my Bomex bumper will be here by then so ill have a bit more room and do the lot in one.But if i need extra pipes unions etc. id like to gt them before i start.
Are you confusing the engine oil cooler and the autobox oil cooler ?
The jap engine oil cooler can be directly replaced with a UK one - it's about twice the height.
The auto box cooler is built into the rad and uses one side on a jap rad and both sides on a UK rad (IIRC). However, you can bypass that and install a new cooler down in front of the main rad at the bottom. Obviously for that you would need different pipes etc etc. There are some good details here http://www.mindserv.co.uk/atf_cooler.htm
