Hello all!
ย
Need advice again. I will be investing in some new PCV valves and pipes in the near future. Anyone know if these are difficult to replace?
Any links to images/diagrams would be most appreciated.
ย
Cheers all.
Anybody got a clue?
:D kit is easy to get hold of ;) but fitting um is a bugger...:( thats why i'm waiting till i get me new rad so will do it all at once :cool:
Thanks For Advice Boys.
I'm gonna do mine tomorrow along with a few other jobs. I'll make any notes of difficult/awkward bits and might take a few photos. The write up on the tt website is good but written for a left hooker, so a lot of the stuff you need to remove is on the other side of the engine.
ย
I'm also removing a turbo technics breather kit and putting it back to standard so I might incorporate that in a write up if it would help anyone else...
ย
ย
Derek
I did mine at the weekend not a bad job apart from the clips holding the wireing harnesses breaking.A good tip is to cut the old hoses it makes life a lot easier.
Hi! Did this job yesterday, wasn't too bad at all. I also removed a turbo technics breather kit at the same time. I made a list of stuff that needs removing, let m eknow if you want it and I'll post it. Also took a load of photos which I can post on here if it helps. Oh, I also changed all 5 pipes including the little bu***r at the back, as the others were in such a crappy state inside. But frankly I wouldn't bother. It was a nightmare to get to and refit, with spring clips firing in all directions... It was also virtually clear compared to the other pipes I removed...
