Headlamp Bulb Question
Just got a nasty surprise while attempting to change a headlamp bulb on my UK Zed. The previous owner has used some odd bulbs and spliced a double spade connector into the loom to connect to them.
The bulbs have the sam two notches as the standard halfords type 453 that I was expecting but also have two spade connectors. They also have the marking X1JR on them.
Anyone have any ideas what they are and where I can get replacements since halfords are no use for these
sounds like someones put j spec bulbs in, if so theyre H3C bulbs, but beware they are poo as theyre 35 watt and cost upwards of a tenner each.
Looked further and they appear to be the Jap OEM bulbs. Now I'm reaaly perplexed as to why anyone would go to the trouble of splicing the loom fit these.
Zed Centre have them for £17 each plus VAT and delivery. Ouch. Anyone know where I can get them cheaper?
35W :) Now I know why I thought I was going blind
you were warned, it will also fall off if you play with it too much. :rofl:
I'd convert it back to UK spec and use the proper bulbs.
Can't be that difficult
Richard :cool:
I have a jap import with those twin spade connectors on.
Halfords make were not the right base shape to fit.
I think you need the ones with the "H" cut out on them...Below is the original bulb:-
These are for Low Beam!!!
Looked on EBAY and i bought n fitted with a simple solder conversion:-
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=72235&item=7948087747&rd=1
These are the ones with one lead coming off.
They cost £6.99 for a set of 2 inc del.
Input power is 55W.
Output power is 110W/100W
:hyper:
Try this link to a forum thread for links to the conversion:-
http://www.300zx.co.uk/forums/showthread.php?t=42922&highlight=low+beam
:x: Not sayin its what you need but might give you an idea. :nelson:
Good Luck
