- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
can any one help i have a uk spec zx when i bought it the passenger side headlight dip beam was wired into the drivers side so i decided to connect it back up and hey presto dim dip worked but the passenger side headlight sometimes works ok and others it won't work however dim dip always works with no prob so is the problem my dim dip unit or the main light switch? also where is the dim dip unit located?
now to my second problem my cruise control won't work it turns on but thats about all it won't set to a speed, when i was poking around under the bonnet the other day i found to round sensors one on each side which take 3 vacuum pipes and have 2 wires plugged into the top on each both have had a vacuum pipe disconected are these to do with the cruise control if anyone has any ideas why it's not working or what the sensors are let me know cheers guys & gals. :headvswal
