HKS filter element size?
Hi there!
I need to buy a replacement filter element for my 300zx tt - it has an HKS green 'mushroom' type filter in it at the moment. The problem is the car isn't here at the moment, so I can't measure the size, but are they normally 200mm or 150mm ones on our cars? The guy on the phone said it would almost certainly be 200mm, but to check first.
Oh, he also said they sell yellow replacement elements. I take it the colours aren't coded for different types / levels of filtration are they?
Derek
If it is a single filter like mine is then 200mm. They come in a range of colours:
http://www.hksusa.com/products/?id=787
-Andrew
£25 from Option Motorsport at Silverstone... Could probably get it cheaper if you phone around a bit.. ;-)
I've got an HKS filter on mine (200mm Dia.) If your not sure then it only take a matter of minutes to whip off the front panel and get the filter off. Mine actually had a label on the back so i didn't even need to measure it.
Thanks, yeah the car wasn't here and I needed to order one but couldn't measure it. Anyway, one's on the way now. ;-)
