advice on removing door mirror assembly
well i have managed to remove the mirror and the shroud but cant get the motor mount from the door frame and i cant see how it comes off ...there are 3 screws underneath the mirror mount but they just loosen the white metal insert i think how do i get the full item off and where dosit connect to ????
any help much appreciated
Steve
ul have to take the door card off steve, then take off the plactic cover on the inside. couple of screws in there, then you need to disconnect the electrics (trace along wire and pull out connector)
yas
Hi Yas
thanks fo the info should get it off today when the gales subside a bit
do you have a door mirror divers side from the zed you are breaking for spares mate??
steve
