I have a diagnostic faukt code that idicates the Detonation circuit. Is there an easy way of curing this!?
ta
p.s will subscribe as soon as my computer will let me pay via paypal!!!!
Hi,
You can try cleaning the connector, if that doesn't cure it, it's more than likely the sensor which is quite a bit of work to change :(
Vijay
ta
There is an easy way of curing it but it is by no means a safe option, you can use a 1meg ohm resistor and short out the connector on the loom side which will fool the ecu in to thinking that all is ok , the downside of this is that if there was a problem the engine has no way of protecting itself , tbh the only way is too replace the dett sensor which is a right pain in the butt as its situated in the middle of the block and the only way to get to it is by ripping all the top end out
Ryan
Thanks guys,
sounds expensive!!!!!!!! I presume if the sensor has gone then my car will be set to safety and wont boost or run properly, cos it sure aint!!!!!!! the missis is beggin me to sell and i dont want it to come to that!!
Thanks guys,
The car should still be running properly but just not at its full potential the timing will be a little retarded and the boost will be running at 7psi as opposed to 9psi
That sounds about right, although boost is intermittent, never know whether its gonna go or not, so prob got another prob!!!! Defo intermittent prob with speed sensor too!!!! See what it'll cost and maybe swap for another zed and hope she dont notice!!!!! lol
well if you need a quote for the work give me a shout
Ryan
