How easy is it to........
remove n/s turbo!!!!!!! last year i decatted the car but whilst trying to undo the pre-cat, i snapped off one of the bolts :cry:..... i have to remove turbo now because it is blowing quite badly from the joint between the de-cat pipe and turbo.
Have i really got to remove the engine or suspension for this job.
many thanx
Dave
Have you tried drilling out the remaining bolt (or stud ?) using a flexible drill shaft ?
yep cannot get nothing in there it is the worst one to get to out of three
hi dave your alive
did the near side turbo with motor in
not easy mind
this will start a row lol
steve
hi dave your alive
not easy mind
steve
Not even going there !! :x:
Alan.
can you drill it with a slimline air drill with a 90 degree head on it (same as a air ratchet,but with a small chuck set at 90 degrees
hi dave your alive
not easy mind
steve
Hi Steve yep still er i moved house recently,and put the z to bed in oct so out of sight out of mind.
But new year and starting to sort out the niggles from last year,starting with this bloody stupid blowing coming from the turbo.
Anyway come on start the row! .......................how was it done?
By the way how is Fem behaving herself??
cheers
Dave
ps owe you for that cruise control ecu [still not fitted yet!]
dont no how fem is havnt seen her for a month
she was going well last time though
id forgot about that ecu thanks for reminding me
not selling the bannana then bud
steve
many thanx
Dave
yewcheck
Is it blowing between the decat and the elbow or between the elbow and the turbo , either way you can just remove the elbow and put another on in which case you will not need to remove the turbo (elbow is the bit your O2 sensor sits in)
Ryan
steve
Have continplated it i have moved 20 sec walk from my office and the only time i got to drive her was to work!!!!!!!!!!
If i dont use her i will sell because i do not believe in owning a car but never driving it.
Will let you have 1st refusal buddy
cheers
Dave
yewcheck
Ryan
Hi Ryan [hows buisness] thanks for the reply by memory :xxx: the blowing is coming from the little decatt pipe [in place of precat] and the turbo! [i thought it was the turbo!!] so i think it is the elbow to turbo :confused:
cheers
Dave
