Poly ones, delrin ones or Ally subframe replacement bushings?? :slap:
Want to replace these over the next few weeks and not sure which to go for, anyone recommend which is best and where to get a set from..... ;)
cheers Jon.
cheers Jon.
not sure i would want to go with ally as you need a certain amount of give which is why you have rubber bushings pretty sure its not gonna do the car much good on UK roads , Luke at the zcentre does a poly kit which isn't too bad or you can get one from Courtesy in the US which is good value , with most of the bushes you will need or have access to a good quality press
Ryan
Jon
Can get you which ever sub frame bushes you require mate :)
Jon
OOPs forgot to say Chris at Getgreddy can also get them :bow: :dance:
