Me again.
So I have two questions:
RobHowl ·
I remeber some guys on here wanted brighter bulbs.
I came across this US site which sells a HID kit.
They are rather pricey but mabe someone in the UK can supply them cheaper or a similar kit.
http://www.midnightmoose.com
