Me again.
So I have two questions:
RobHowl ·
Leak in heater matrix.
Have removed all the dash/trim fittings etc and got to the point where the heater unit is 'free' but will not pass by the A/C cooling unit.
Anyone out there know if A/C unit has to come out first or is there a 'shortcut' to achieve 1" or two just to allow heater to come out?
Ben
