Help 2 Cylinders Not Working!!!!!!!!
My Twin Turbo 1991 import is running on 4 cylinder instead of 6,
I have cleaned the injectors connectors, coil pack, swapped the coil, plugs around Constantly same cylinders dont work, ran ECu diag and code 55 ???????..............................................................................
Can any one shed light on this problem????
I am considering buying a new series 2 PTU...................................................................
If there is any out there who can fix this problem or shed any light i am will to £pay...
Give me a call with your address, and I will send you a PTU to try out :)
if you have a multi meter you can check that there is a current to the coilpack connectors also check/clean the connectors on the PTU if you havent already. then its probably new PTU time! :(
