Are these worth fitting?
Hi Alex,
Yes mate, but the result is usually only noticable under hard cornering. The result of fitting both front and rear strut braces is flatter cornering and hence the ability to go through corners at a higher speed due to increased grip/adhesion to the road. There is not much point in just fitting the front bar as you'll be introducing a mis-balance into the handling equation. If you really want to go all the way in enhancing the car's handling you'll need to buy front and rear upper strut braces, front and rear lower anti-sway bars and for the die-hards amongst us you'll also need to buy chassis braces which are welded directly to the chassis and suspension.
If you'd like to buy some strut braces I have them in stock at the moment. Take advantage of our christmas promotion (quote: XMAS04 at time of ordering) and receive a 10% discount!
Take care buddy.
Danny
