Hi there. Seen a lot of postings on here regarding this, but when hot the idle hunts between 500-900rpm, and occassionally stalls when you lift off. Standard ecu, passes diagnostic. It's running 12-13psi. I'm going to clean the throttle body this weekend when I do the suspension and brakes (busy weekend!), but should I also do the fuel pressure regulator and fuel filter as a matter of course? Can't find out when it was last done before I bought the car, and I have only covered 2500 miles in it. Cheers, thanks for all the continuing good advice!
Derek
PS I have a lovely shiny pair of Japanese adjustable upper arms and tension rods looking at me in my hotel room here, just shipped from Courtesy! ;-)
Derek
go round giving all the connectors a good clean be surprised what a differance it can make,unfortunatly theres a few things that can cause idle problems but by eliminating them one by one
change fuel filter
clean TPS connector
clean IAA connector
clean MAF connector
throttle bodies
good site on fault finding http://www.300zx.org.uk/ and checking connections HTH :cool:
Best be careful...................
.............Theyve just banned hunting!!!!!!
