Alarm Location
Hi All i have a clifford 500 cat1 alarm which was already fitted to my zed and i need to remove due to some problems with it but i have been stripping down my zed all day and i cant find it.I found the siren and microwave sensor but the wires disappear into the main loom and i cant trace where they go......I need to know any common places they would be installed on a zed as they are quite hard to fit anyway due to not having much room in a zed.....I want to replace it with a toad ai606 that ive already purchased....
Any help please!!!
:cry:
Any help please!!!
:cry:
My "control box" was mounted behind the stereo for my last alarm system. Do you have any indicator LEDs on the dash? They're usually not far away..
Steve :)
'93 UK TT Manual
Centre consul/dash is a good place as all the wires are there!!
Brave man removing it yourself...The thatcham approved alarms are well wired in and become part of the car...not as simple as chopping the wires to take it off..
Theres someone on here..Bob from safe&sound in the traders section he would be better to ask as he knows....
Yes i have a red led in the centre dash next to the clock
took all that dash out other than the heater unit...unless its behind that??
My Clifford has a bit under the dash rhs of steering wheel with a pot on it for sensitivity, a bit under the hardboard panel in the boot on the nearside connected to the sensor thingy and another main bit behind the trim panel right side rear seat. - or was it left side? all the wires are black and the car actual wiring connection record diagram I got was printed on that shiny fax paper that goes white eventually leaving you with no idea where the connections all are. Wonderful. Also the siren is down under the nose and it has its own batteries that mean it keeps going even if you cut the wire to it.
I had a problem with mine due to a flat battery and found the hidden bits by disconnecting the siren and letting the alarm go off- then you listen for relays clicking behind the various panels to find the bits.
Needed to use an access code to get valet mode then to re register the remote to the alarm. No more problems
Bob will know for sure
Give me a call if you want, not telling you the hiding places on a public forum!
Bob 07770268705
my alarm aswell was fitted on my zed and two days ago it stop making that beep every time i activate and desactivate it .the alarm is a laserline 996 v2 .can anybody tell me if is got a battery or something cause i don't know...in rest the alarm is working no problem ,is just that beep. any ideas...please..
:dance:
