Det/knock sensor
Is it ever worth re-locating the det sensor or should it be replaced in exactly the same place where Nissan intended?
Nissan put it there for a reason , I have seen and read write ups on relocating it but tbh where it is located at the moment is the best place imho
Ryan
I just had this done and
1) I wish I'd got Baggins to do it
2) The world renowned Lymon agrees with Baggins. Even though the idea for relocating came from another Z guru (Henri LeHir) so it should work, it is still a get-round rather than an upgrade.
3) If your knock sensor is gone, odds are there's loads of little bits which can usefully be done at the same time. Hoses, PCV valves, fuelpipes, injector o-rings, coil-pack connectors (or even engine harness), timing belt, water pump etc etc. It's a big job so give yourself time to plan it and get the parts in advance. But when it's done (as long as you don't get a cowboy to do it) the top bit of your engne should be OK for ages (fingers crossed).
Think of it as a whole shedload of preventative maintenance.
As the idling has been very slightly up and down and i'm a little more than fussy when it comes to having a car that runs perfectlyin the last few weeks i've done:
PCV valves
New plugs
AAC and the two other valves
Throttle bodies
Clean out idle screw
New temp sensor
TPS on it's way will fit this weekend.
Checked the resistance between the connector and the ECU from the Det Sensor and it's fine.....checked the resistance between the connector and the Det Sensor and it's ***ked.
Baggins is fitting a new one and a chip Saturday.....
My parts list was:
Sensor - Oxygen RH Z32 90-93 TT/NA 22690-30P00
Sensor - Oxygen LH Z32 90-93 TT/NA 22690-40P10
Sensor - Knock Z32/A32B 22060-30P00
Sub Harness - Knock Sensor Z32 24078-30P00
Gasket - Plenum Z32 14033-30P02
O-ring - Balance Tube (2 required Z32) 14033-30P05
O-ring - Balance Tube Z32 14033-30P06
Gasket - Throttle Body Z32 16175-30P70
Gasket - AAC/IAC Valve Z32 23785-40F00
Gasket - EGR Plenum Z32 14719-30P05
O-ring Injector Lower 90-92NA/90-94TT Z32 16618-10V00
O-ring Injector Upper 90-96 Z32 16618-10V05
Insulator - Injector Bottom 90-94 Z32TT 16635-10V10
Connector - Coilpack Z32 24079-85M00
Sensor - Head Temperature Z32 22630-51E02
Harness - Head Temp Z32/Z31 24079-01P00
Harness Kit -A32B/Z32 Inj. Conn/3 qty 24079-25P26
Water hoses under the plenum
spark plugs
Inlet Manifold Gasket 300ZXTT 14035-30P00
Cam Belt, Z32 13028-45P86
Down Pipe Exhaust Ring, Z32 20691-30P00
Thermostat, Z32 21200-42L01
all this from a £15 ConZult test at Billing ffs!
