6*9 in the door
has anyone fit 6*9 in the doors and do they fit easy or is there some cutting etc to do. any help before in attack it tomoz. thanks in advance graeme
my m8 put 6*9s in his doors
little cutting away to do
no big problem if youve got a dremmel or something like that
do a template first
I managed to fit 6x9s, I removed the outer metalwork and made some small mdf mounting rings.
Barry.
6-9 no probs but had to remove the steel baffle type thing,make sure you get the cut right coz you cant get bigger than 6-9 to hide the wrecked door card
brian93tt
i mounted 6x9's to the existing metal plates. had to grind them out & weld them up tho!
door card needs modifiying also.
it will depend on the speakers as well, some 6x9's are very deep & will not fit as the window wont clear them.
I had to fit two 3/4" packers between the door card and the door, for them to fit and clear the window
