where can i get my speedo changed to mph
can anyone tell me where i can get my dials changed to mph,and can i get some fancy dials put in,,,ps and how much
luke at the zed centre can do this, if you are near nottingham or you could just send your whole dial cluster to him to do. from memory was about 140 inc fitting for a set of white dials (not the glowy kind) and a few squids more for the speedo conversion...
thanks davido will look into that,,although notts is miles away from me could be worth sending off for
if you are looking at doing new faces for your dials it really is best to get somebody who knows thier stuff to do them, if you get it wrong you can kiss goodbye to them and have to go buy a new set, something to do with the little pins coming out of the dials, once out they dont go back in!!! Luke did a fine job on mine and re-did the speedo conversion cos mine was a bit flakey.
It is however 5mph out over the whole range now but as long as i dont forget that when the old bill are around I can live with it :) (can be re-calibrated but I cant be arsed!!)
It should read in MPH :confused: if it doesn't how has it passed the MOT, now thats what i would be asking...!!
i didnt know the speedo was part of the m.o.t its passes 2 mot,s since ove had it at 2 different garages
hi, i am a class4 mot tester and the speedo is not a testable item. It wouldn't fail even if it was missing. :D
thanks steve thought i couldnt been lucky twice
