- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Car: 92 UK spec 300 tt with auto air con
Since my car is off the road with a dead turbo I went out this morning to check out the problems with the air con.
There is a loud ticking noise coming from the auto amp but this goes away when warm air temp is selected and returns when set back to cold air. The air con pump clutch is not engaging and I have checked all the fuses. Could it be that the auto amp clicking is an indication that it has failed or is the noise the result of it trying to operate the pump but unable to do so due to another fault, perhaps the air con relay?
I have read that the pump will not engage if the system is low on gas, and although I have checked the sight glass its hard to be sure, but in this case I would expect the system to know this and not attempt to run the pump.
I am no expert on this and am only guessing, has any body ever experienced similar problems, as this is the sort of job that you could end up replacing everything in the hope that you get lucky.
I looked at the self-diagnostic info but got lost in the technical jargon, most of it does not seem relevant since everything else seems to work fine.
If anyone has a spare air con relay or amp for sale please let me know. Not sure if jap spec is the same as uk though.
Steve.
