Razo Turbo Timer
Hi guys, I got to fit a Turbo timer for mrogers, and after a long and extensive search I cant find a wiring diagram, can anyone help?
I hav'nt seen it yet, but there is a few wires loose of the harness that im unsure what to do with.
Many thanks for your assistance, and im sure mrogers will follow this post with the colours of wires.
And before anyone says it, I know red is +ive and black is -ive
Thank you
Hello mate, If your other wire colours are Green,Blue and White, they must be spliced to the Black with red stripe, Blue and hand brake switch Respectively.(in that order)wires under the steering column(ignition). :)
wired are as follows.
main unit
several wires out of back of unit that goto a 6 pin male splice conector.
one very short yellow wire out of timer with male bullet connector on
6 pine male splice connected to 6 pin femal splice that then goes a 3 pin male splice. out of the back of the 6 pin female splice a 3 long wires with no connectors, a blue a red and a black one only the black one has a connector on it which is a fork type. the 3 pin male splice then goes into the back of a 5 pin mle splice the wires that go to this splice are all have red stripes on but are different colours, there is a white wire with red stripe the does not goto the splice but has a male bullet connector on. out the back of this 5 pin female splice are wires that goe to a 5 pin male splice that has a wite and red wire thats arcs across it.
also a black box with bracket on with 1 red and 1 black wire with female bullet connectors on out the top. out the sides ar several wires going to a 6 pin male splice connected to a female 6 pin femal splice that most of the wires goto a 3 pin female splice.
the ones that dont fo there are a green wire a grey wire and a yellow wire with an inline fuse.
as u can guess i well miffed lol
any help greatly appreciated.
KIN ELL! :x: Bit different than mine, youve got the type that splices to your Ecu, for the speed and Rpm measurement Ect. Its a bit more advanced than mine Sorry i cant help you :(
cheers any way neilzy its a razo solid sport car mate auto select timer with rtc whatever that is
SOUNDS GOOD THOGH
steve
RTC=Real Time Clock!
