Det sensor
I need to check the wires between the ECU and the connector a slim hope that this is the problem and throwing the code 34......also i don't want to blow up my ECU therefore i want to double check how to check the resistance.
From the female plug (one with temporary resistor)
Connect one side to a good earth,the other side to the ohmmeter (red) and the other sidee of the ohmmtere (black) again to a good earth?????
It should throw up a resistance of 500k ohm with the engine running....
Is this correct???
No posts to show
