Boost
Thinking finally of boosting............. ECU upgrade first followed by boost controller.
All works fine apart from code 34......
if i just use a resistor instead of pulling the whole engine out and fixing, can i use the boost controller????
Also if the resistor blew would this make any difference?
Finally how much should i pay for ECU upgrade and boost controller and which boost controller should i use....is the Greddy Profec II recommended.
I want a small and compact controller.......
Alex i can provide you with both and when the ECU and boost controller are bought together i offer a good discount :)
If you want a small unit then its got to be the profec B II
