tugging to the left
Have noticed that the car pulls to the left a little when driving either at speed or slowly, put it down to slightly wonky tracking or just the car following the road camber. (so going to get it sorted soon)
Although today when driving very very slowly (doesnt happen very often) i noticed a very definite tug to the left, again and again. The steering wheel jumps just a degree or two to the left (when I hold it very gently) over and over, does this still sound like tracking? im not so sure any more.....
If it's not tracking it could be a leaking suspension shock, that's the problem I have at the moment.
Mine had the same when i bought it i think these cars are very sensitive to worn tyres..i replaced mine and the problem dissapeared completly.
If they are worn slightly unevenly it may cause this.....how old are they?
dont think the tyres have done too many miles, ive probably done a thousand or so since ive had the car and there is still loads of tread left. there is a touch more wear on the insides of the tyres but I had put that down to slightly saggy suspension putting the camber out a touch, nothing to write home about. no evidence of other uneven wear... will have to get a proper alignment done and the shocks checked over..
That's exactly what i thought in fact you'd hardly notice it looking at the tyres but because the tracking was out the tyres were worn badly therefore pull to the left.
I also had some annoying vibration which also disspeared after new tyres.
Just use the spare and try it on both fronts just to be sure put it on and drive down a straight road see if there's any difference....
