50-60 mph vibration
any speed, any gear (auto) but sometimes bad vibration only at this speed range, goes after 65 ish, slow down and vibrates till below problem range
any ideas?
Thanks,
Rob
any ideas?
Thanks,
Rob
Hiya Rob,does the whole car vibrate? or just steering etc?
prop centre support bearing is favourite. Rubber bellows in the bearing support goes hard and perishes and splits leaving the bearing sagging on the mount. Usually gets better as the car warms up. Think of it as a 10ish year necessity for replacement
Definately sounds like your Propshaft Bearing dude, I have had them go on both of my Z's and you can feel it right up through the drivers seat from approx 50mph upwards particularly if you accelerate hard.
if its at a certain speed could also be just the wheels balance or tracking worth getting them done just to try!!
Any clonks on acceleration?
get the wheels balanced first, cheapest option and probably the cause of the wobble!
:confused: ;)
If the Vibration feels like it is under ya seat !! then i would say it is the propshaft bearings :( I know cos i just had mine done ;)
Now a happy bunny.......:D
ive got this problem too
where can i get it done and approx ho much ??
Well just for the parts it's around £185.........:shock: and then ya got fitting..:( all in fitted mine cost £285.
Check Rear wheel bearings as well mate.
bloody hell :shock:
are they gold plated
Not if you go to see Baggins (Ryan) at Z TECH...
guys thanks for your help will have to save some pennies and get it sorted..def sounds like prop thingymajig
have you got some contact details for baggins tattooman please mate..is he really cheap then :)
Ztech in the traders forum
Why's that then mate is he going to pay my fuel bill ;) ;) there and back.
I've got two auto props in my garage with good centre support bearings. £45 each +p/p.
Oh Yes.................
LOL no he's not bud :rofl:
I bought an import about 3 months ago and it had a vibration that only lasted for about 5kph around 60/65kph on a NA. I got the Prop bearing done and it fixed it completly. Its not too hard to foi just need to rremove exhausts, should cost you around £250/275 but is really worth doing.
  • 3 weeks later...
:confused: if this is left what can happen, anything serious coz ive got the same problem, also my speedo cuts off at about 135mph everything else runs but the speedo only starts back up at about 20mph!!! whats going on??? :confused
