Tb22
TB22 Hybrid with 360 ° bearings,what are they able to take boost/bhp wise, ;)
Tony
arnt TB22's stock tubs?
if thy are thy wont flow any more air than standard tubs with boost controller (efficiently anyway)
360 degree Thrust bearings are supposed to be able to hold 2 bar although as ya5een says they will be completely inefficent after 16psi ish but if they are a hybrid then I presume they will have a bigger comp wheel etc so you may get a little more
Thanks guys,still not certain,but mine are rebuilt T22 with 360deg bearings and bigger compressor done by Turbo Dynamics,and seen as my engine was built to take around 25psi(allegedly)was not sure if the tubs would handle much above 15psi,so maybe they will go a tad higher,being a bit of a mismatch i still have stock injectors,still got boost controller to fit and chip,other bits, so soon as i get round to it(so busy)will get to Thor when its all fitted,then just see where we max out with this set up,but the biggest stumbling block will be the injectors i think,will soon reach duty cycle limit,still,all fun :cool:
Tony
