Hicas sensor removal
If this is removed will it cause problems,or will the hicas just not work[which is what I would prefer!]-what I mean is will the rear wheels remain 'straight ahead' at any given speed with no input from the sensor? :bow:
Well its 1 of the best things i have had done to my car..;) Speak to John Dixon on how to short it out mate.
then if you do like the difference then you can always remove the lot and put a Hi-cas bar on..;)
Cheers m8,eliminator will come later ;) just wanted to know if I can bin the sensor with no probs?
Think you can, the HICAS ecu should just interpret it as a fault and lock the system. I usually short the fluid level sensor to do the same thing.
Cheers JD :D
