turbo smoke
fitted two near side turbos in 300 miles
after each one there was loads of smoke
fitted new oil pipe this time
car still smokes abit now and then
not all the time
how long would oil in pipes and intercoolers take to burn off
steve
feed mate
steve
did you check the return as well? Not that this will make it smoke, just asking seeing as you have had a prob. The oil cant get in if it cant get out. If you know what I mean?
Quite a lot of oil can get into the coolers etc when a turbo fails and it might take some time to go fully, but I would guess it wont take long before you cant notice it burning. A lot of air is pushed through when you are driving. How many miles have you been? And make sure everything else is OK too, sometimes you can miss something...
thanks for the reaply mark
ive only done about 120 miles
yes i did check the return
i noticed it smoke more after i jacket it up on the opposite side
thats why i was thinking oil in the intercooler
steve
It could "pool" in the bottom, and depending on the actual flow through the cooler it might stay there for ages. Sounds like take it off and clean it, or drive it and see. Depending on how brave you are. I think if it was me I would take it off, or remove the pipes (?) and look/clean. Especially after the probs you have had.
ok thanks mate
steve
Could also be oil left in the exhaust system burning off ;)
not that it would happen to you duffers ;)
Well if it wasn't from the experience of these things happening then I'd know about as much as you do :tongue: :x: ;) :D
dont worry about it my apprentice one day you will learn the ways of the kirbz :tongue: :rofl:
Nah.... you're ok thanks mate! :tongue: :rofl: ;)
youve got it all wrong the bag should be pillar box red :rofl: :rofl: :rofl:
Just a thought, but I had the exact same problem. Swopped the PCV valves from side to side and when fitted them the other side smoked ! :rolleyes:
Swapped the valve from my mates and it cleared up. As a matter of interest we fitted my suspect valve in his, and it smoked like a good-un !!
Cleaned the valve and re-fitted it, still the same, so even if the valve is clean, I guess it can still be faulty ???
Dunno, but maybe worth a try mate ??
Alan..... ;)
thanks guys
should do my pcv valves anyway
steve
Thought you'd done them first?
no not yet thought it was them but it was the turbo f@cked
twice but as it isnt smokeing all the time i think i will look at them
steve
