Knocking under the car
Have a loud knock and a bang from under the car when I accelorate and then slow down, on the point of slowing i get a massive knock from unther car on the passengers side, its bloody loud and you can feel it through the car too!
I replaced the tension rod arms with rose jointed ones as the silicone bushes had split thought this would sort it as i could see nothing else bad under there, but no its still doing it???
Anyone have any ideas where to look? :cry:
Is the car an import??
Have you checked for an immigrant hanging underneath? :D
Sorry, I'm in naughty mode today :slap:
Simon.
Exhaust mounts. Mine did the same. Check underneath and theres a mounting bracket at the back of the gearbox that the exhaust hangs off. It uses some little rubber mounts if I recall rightly. My bracket was totally missing (had a gearbox rebuild before I purchased so assume they didnt refit it) and it was that that was making a very loud banging.
Nick
:cool:
I pretend to work, they pretend to pay me!
Nice one Nick will have a good look there :bow: , but I'm sure its comming from around the wheels? Mainly passenger side.
Tension rods aren't tight enough. Get under the car and re-tighten the nuts that attach the roads to the lower wishbones - they have to be ****in tight tho so get as long a lever as possible ;)
Upper arms as I've mentioned in your other post ;)
