Swirl pot
Just a quicky, does any one no if this will be a good idea on the zed? im thinking if putting one on mine to see if it helps the pressure in the rad?
Hanksy
anyone? or was this bloke talking shit? i aint got a clue thats why im asking.
Cheerz
Hanksy
Swirl pot is to remove entrained air from the coolant. Won't do any harm, but I'd say it's unlikely to stop pressure build up. Might be a bit difficult to plumb in on a z too.
Not sure about pressure but it will help with cooling, if fitted correctly.
If something is wrong with your cooling system then this wont fix it. If it works right then this thing is not needed. Either way whats the point? If you want uprated cooling go with a UK TT radiator as it has 30% more cooling on it than the import TT one. Your worry would be from pressure coming from a blown head gasket or overheating from a clogged radiator matrix.
