MOT advice
not if its just slightly worn.
reasons for failure (among others):
a cut which causes the fibres to separate
fluffing or fraying sufficient to obstruct correct operation of the belt or which has clearly weakened the webbing
stiching badly frayed, not secure, incomplete or repaired
also
a retracting mechanism does not retract the webbing sufficiently to remove all the slack from the belt with the locking mechanism fastened and the seat unoccupied
cheers Paul
It is slightly frayed where the buckle would typicaly sit, so it may be a bit 'iffy' . I'll put it in and see how it goes.
Robin
