Oil Pressure what should it be?
I have a 1994 N/A Auto with no mods at all,
Can some one please tell me what the gauge should be reading
at various rpms
ie tick over, 2000rpm,4000rpm
Steve
>11 psi at idle, engine hot
51-65psi at 3k rpm
the stock gauge is pants tho & this should be measured on an aftermarket gauge or test gauge fitted in place of the stock sender
Thank you Paul
I only have the standard gauge so will get off to the garage and get it checked.
std guage has a sensor that only lasts about 40k miles then measures lower and lower occasionally measuring normal for a while.
Look inside the oil filler at hot tickover and re assure yourself there is pressure. It should be flooding with oil in there.,
