Fitting Chips
No not fish n chips! has anyone ever fitted a chip in the E.C.U? as i just got one from Friday and wondered if they soldered in or ''push'' in? also is there a top/bottom/left/right etc?
Thanx for any advice ;)
they are soldered in, you are best just cutting the old one out, desoldering the legs, soldering a socket in then putting the new chip in that
ooo! easy job then!! :rolleyes:
Ta Scoops.
it is easy if you have experience in soldering, if youve not done it before then id get someone to do it for you.
Soldering shouldn't be a prob,think i'll get another stock E.C.U tho-cars used every day and don't want to be of road if I fook it!
ANYONE SELLING A STOCK E.C.U[jap tt auto] :rolleyes:
From personal experience (and also because I sell a lot of chips ...) get it done professionally. It is so easy to get it wrong and ruin the ECU by either over heating the circuit board or not properly desoldering the legs. A professional outfit will desolder all the legs at once, lift out the chip and leave no residue. This service shouldn't cost more than about £25 (+VAT).
As for putting the new chip back into the socket correctly, make a note of how the old chip was fitted. There is a small depression at one end of every chip - make sure you know which way round it is. If you fit the new chip in backwards then you will blow up the chip and render it useless (your ECU will be ok).
Good luck!
Danny
i've got an eprom chip which i've been meaning to fit, it has a socket with it and thought i'd give it a go today, noticed one of the leg on the socket was a little bent, so starghtened it up :rolleyes: .......doh.... and snapped it off :slap: ......anybody got a spare socket they dont need?? :bow:
Cheers Guys
Neil
Cheers Guys
Neil
Bugger, got a spare chip[jwt]-can't you break that as well! :D
only if your going to GIVE it too me, i break in front of you if you like :rofl: :rofl:
:nono: ;)
Cheers Guys
Neil
Doh!!
If you have a maplin electronics near you, they'll have one no worries!! ;)
