Clock and Mirrors stopped working
Hi guys,
I've just had some work done on my Z and have found the clock doesnt work at all and neither do the retractable mirrors. Do these run off the same fuse? Or does their wiring both go through the centre console and somethings been dislodged?
Thanks for any help.
Dave.
Sounds to me like you've blown two separate fuses (I managed to blow 5 all at once, don't know how).
Get some longnose pliers and pull each fuse out in turn to check. The fusebox in the driver's side kickplate next to the pedals is the one you want.
As you remove the panel in the footwell you should se a little plastic fuse removing tool attached to the inside of it
Richard :)
nope these run off the same fuse. Your front winscreen wipers will work but the back one will also have stopped working.
Drivers footwell 3 along on the top row 10 amp ;)
SMW1 you f***ing genius!!! thanks for that buddy :bow: there was no fuse there at all so no wonder i couldnt find a broken one! there are still 3 missing so i wonder what they are... there's a :duffer: waiting if ever i meet you bud
