help with boost gauge fitting
try as i might i cant feed the hose through where the bonnet release cable hole is.used a knitting needle to pass through but cant locate where the hose would be coming out to any help,does it come out below the master brake cylinder or lower :rolleyes:
secondly do i use the plastic nylon hose or should i use some after market silicone cheers for any advice :) greg
has anyone fitted the gauges from the group buy of chris ie..water temp
  • Replies 30
  • Views 1.1k
where bout's you fitted the guage??
A-PILLAR boost&water temp so i have to extend the wire for the sender to the rad pipe dont mind :)
but id rather fit all the wires from the gauge to the headlamp pod but me thinks i cant :rolleyes:
Right then,I fitted mine on top of dash in the corner near the o/s pillar,and wired the light feed straight into the light switch pod-only difference with yours is that you need a feed from ignition/accessory circuit,but i'm sure there will be one in the pod for cruise/heated rear window etc-just got to find it! ;)
SHAMORE going to extend all the wires in the morning wire it up and il post some pics of the finished article thanks for all the help though bud ;)
