FAO Conzult experts
Plugged my car into my conzult, jacked up the back of the car, put her in park and selected similation drive in the hicas menu. turned the steering wheel but could not see the rear wheels moving. am i doing summat wrong or does my hicas not work.
Was the engine on ? (HICAS needs hydraulic pressure from the pump to be able to operate)
If it was, then there's probably something wrong with your HICAS system
-Eric
yeh engine was on. any problems with hicas not working.
Hi Eric,
I had the same thing on 2 cars I tried and couldn't get it to work :(
Vijay
Vijay, was it showing readings of the sensors ?
And what version of the software did you use ? (v2.0 should work fine..there were problems with v1.2 and v1.3)
I had a chance to test/demonstrate it on quite a few cars at Billing and it worked fine for most Zeds.
(except for the ones that had HICAS disabled or those that were known to be faulty)
It even worked fine on a few Skylines I demonstrated the conzult on :)
-Eric
So would it really still work with the autobox in 'park' ?
Hi Eric,
I haven't tried it on ver 2.0.
Vijay
It shouldn't cause any problems, unless the rear wheels are locked in an incorrect position or when the HICAS rear power cylinder is allowing too much free movement on the rear wheels
Yes, for autos put the gearbox to "P", for manuals put gearbox in neutral
-Eric
does the consult do the auto box diagnostics as I have seen the menu but it doesn't work, ...........unless it has to be plugged in somewhere else
