Scooby Blitz...will it fit??
The filter itself may be OK to use if you have the correct base plate which bolts onto the AFM.
Otherwise you could try and make your own, or try Demon Tweeks as they sell adaptors. The ZX gulps a lot of air so you need to make sure the neck is a reasonable diameter, not like the narrow ones found on lesser cars.
Richard :)
is the AFM on the scooby not the same part as on the zed? in which case I would have though it would bolt right on.
no idea mate :S
What your wheels and zorst there mate?
