winter reminder
remember peeps winter is on its way and some of you wont know that the water in a 300 battery evaporates because of the heat under the bonnet its worth topping up b4 you knacker ure battery up with the cold
That is a very good point. Better check every thing really.
Remember to wrap up nice and warm too.
Also remember to turn off the traction, run at last 2bar and always enter the high street sideways. smile.gif
Must get a matching set of Hat, Gloves and scarf for the Z.
Arrrrh....all rapped up nice and warm, with a glove on each wheel a hat on the T-tops and a scarf lovingly wrapped around the bonnet.....(you'll have to exscuse me as I am still piffed from last night!)
Makes you all warm inside....
(off to check me battery)
Matty.
Bounce...Bounce...Bounce...Bounce...Bounce...Bounce...Bounce... (sorry no sound!) LOL
Don't forget to fit snow chains at the first sign of frost or just leave the Z garaged for half the year...
What anti-freeze should I use - heard something about the wrong stuff corroding radiators? I've had a few overheating problems and so no green stuff in my radiator at the moment...
Premixed antifreeze and soft water.
4Life (v. expensive) or Comma Coldstream are excellent:
http://www.commaoil.co.uk/afc.htm
the only type of antifreeze to use should be made up of ethylene glycol and not methanol mixed. as the ethylene has anti-corrosion inhibitors and also acts as a summer coolant which you can leave in for a couple of years.the make of manufacturer is not as important, I USE CASTROL OR BLUECOLL.
as my heater matrix breaks with such amazing frequency i never need to worry about yearly changes of antifreeze as middlehursts change it every eight months along with the matrix lol
