...when both my doors and the boot are shut properly?
Thanks,
Mooch
sounds stupid reply but have you moved the little black switch on the interior light itself!
can be on permantly,permantly off or set to come on when doors are open sorry to state the obvious :rolleyes:
Sorry, I suppose I didn't express myself very clearly. I mean the red warning light on the instrument panel that shows a picture of a car with its doors open.
Check the fuses in the drivers footwell, there's a little 7.5amp fuses, if thats blown that may be causing it
Your boot is open!
if you have a alarm the bonnet switch might not be making good contact, to test it unplug it and see if the light is off
I recon its a dodgy switch, probably lost the connection on the door pin. Does you int light stay on also if you put it on the open setting?, if so, I would 99% say dodgy door pin.
Whip the screw out and have a look (youll ned to unclip the interior plastic trim on the inside a little to get to it, but you dont need to remove it)
