Wiper Arms...that old chestnut!!!
Any suggestions as to how to remove these?..mine looking a bit tatty...
Tried pulling, levering...prayer methods...
They must be welded...
Regardz
just turn them manually or turn on the wiper motor and firmly hold the wiper.
that should do the trick.
-Eric
I know it sounds a bit extream but if all else failed (as on mine) a two leg puller does work ok, the only thing is the bonnet is in the way for the drivers side one so u need two helpers to hold the bonnet way upright. This was the only way I gt mine off after trying every other method! when refitting use a little copper slip on the splines so removal later is easy> Jeff TT
