light problem
hi can anyone explain how to get at the fog light bulbs?the two screws on the front of my lenses just keep turning and don't seem to do anything???also mine is a jap import so can i get bulbs for it here.thanks for any help.
You can get to the front fog lights by removing the indicators. You can then see the nuts that hold the foglights in place. Remove the connector and they will pop out through the front.
thanks your a life saver.any idea on what bulbs to use.is there any better bulbs i can use?
They are H3 bulbs, but if it's never been changed since it was imported, then you'll have 'bullet' connectors on at the moment, you'll need to change either the new bulb to a bullet, or change the car side to a female spade connector.
