ecu diagnostic
Just done an ecu diag and got code 55 :hyper: Got a lazy R/H O2 sensor :(
Anyone in the oxfordshire area with a consult want to swap a prope diag session for some :duffer: :duffer: :duffer:
Robin
Robin
Robin would be more than happy to run a Conzult for you although I am at the bottom of the A34 so just out side oxfordshire
Ryan
Cheers Ryan
When would suit you ? Where exactly are you ? And wot do you drink ? ;)
Cheers Ryan
lol no drink required mate , I live in a village called lambourn , have PM'd you my number
Cheers Ryan
change that can't pm you because your not a subscribed member :nono: , conzult will also be £50 because of this :p ........only joking give me a ring any time after 5 :cool:
07968 166640
Ryan
Call you 'bout 6.30-7.00. If we could do this tonight that would be cool.
Robin
Cheers for your help today Ryan.
Front of my car now totaly in bits. Haven't found any split or loose hoses yet and my Greddy intercoolers look ok.
Going to delve into the recircs tomorrow and work back towards the turbos. Also possible one or both of the wastegates aren't closing properely. Altough the suddeness of the problem tends not to suggest this.
Anyway thanks again
Robin
Mind and check the connectors for the O2 sensors - my lazy one was and oxided up connector - sorted that and its fine. Better than £100 plus a pop for new ones.
Cheers WillieO
Consult says there working fine, guess they were'nt up to temp when i did the ECU test.
Ryan, got the recircs off, can't blow through them, though not sure me old lungs can make 1.25bar of pressure :D
Beggining to struggle a bit as i still haven't found anything loose or split :mad:
Found half a forest worth of leaves stuck to the AC condensor, which may explain why it was running hot.
More later
Robin
