head gasket failure ???
please could someone tell me if im having head gasket failure !!
white smoke from both exhausts !! tons of it, i thought if one side had failed then only one side would smoke is this correct ?? highly unlikely both sides of the head gasket have failed at the same time !!
bit of coolant loss !!
was ok before i did my pcv valve replacement !!
starts and runs ok !!
any help much appreceated
dewi
Too mutch of a coincedence to fail after PCV replace, reckon you have dislodged something somewhere, white smoke usually indicates water (or steam), was it losing before?
Get a compression test done, that will tell you if it is in the limits allowed (you can also get a coolant compression test done to try to find out where it is losing)
Let us know...
