Power Steering Pump
Hi all!
Anyone know if changing the p/s pump is easy?!
The pulley on mine kind of spins its way out about 1/4 inch then clicks back in, I poked it with a screwdriver today and it came out more and started Peeing out fluid , oops! Does this mean it's knackered or can just the pulley be replaced with a new seal i assume?
Any advice appreciated :-)
Cheers,
Anyone? please.
Nobodys ever changed a p/s pump?
Changing it's awkward and messy but do-able.
You need to take the radiator and the bottom engine trays out then you can get to it to work.
I'd just get a 2nd hand unit, replacing the seals will probably be possible but it's pretty difficult.
need to do this my self (replacing the PSP, mines leaking and need to top it up every 3 or so days, been recomended to change the pump as not many ppl go for a seal change.
