Coolant leakage?
I came home today after a drive in the hot sun and saw green fluid leaking from the front nearside. I know it is the coolant but has anyone else had a similar problem? I have taken off the reservoir and found that a feed pipe may be missing. Any suggestions?
:bow:
So you are looking for a Coolant Leak? It looks rather strange a post named "Coolant Leakage?" in the Items Wanted section.
the reservoir has a hole in the neck so that it can not over fill. It is possible that in the coolant in your rad has expanded into the reservoir to the extent that it has flowed out of the hole (as it is supposed to). This would be more likely to hapopen if someone has filled your reservoir up at the same time as your rad, while they both are cold. The heat expands the coolant, which flows into the reservoir (which is already filled) and so spills out of the "overflow" hole. Check this befor epresuming that your reservoir is leaking :)
