big help needed in yorks water leak
im a bit out of my league here
ive got water leaking out of bottom of engine
seems to be coming from rear of bottom belt pulley
got all front parts off
ie fan,hoses,right side drive belt cover etc etc
to the point of loosing track of everything
would i be right in thinking it may be the water pump??
or is it worse maybe head?? :( :( :(
Water pump or the two hoses that feed it;)
how do you know if the water pump is not working if i manage to get it off
Blimey! My mates did exactly the same thing today.
Not sure if its the pump or just the pipes, having a look tomorrow.
If it is the pump, it'll be a cambelt change too!
Probably the sealent on the pump has corroded, if you've gone to the effort of taking it off you may as well put a new one on and resealing.
You don't need to do your cam belt at the same time, I didn't bother, but that just means I have to strip the whole car down again in a few months to change it then,
Just replaced my pump m8
same symptoms
got parts from mike at MJP Eastern auto in the traders section
order
the two water pipes (may as well replace)
thermostat (may as well replace)
waterpump
you'll also need a tube of liquid gasket
about £80 (can't remember last week :rolleyes: )
special tools
6" pulley
I think thats it :rolleyes: but I may be corrected.
Jesus my memory is bad only finished the job off thursday night.
Good luck m8
cheers lads
yes it is the water pump
what a job getting it of
had to strip just about everything on front end
the worse part is yet to come
putting it all back together
