hellllp is it sabotage or what???
im not greatly mechanically minded
hope someone can help me out.
on my way home i noticed it wouldnt go into boost,(just dipped down as if no fuel) i presume this is the safety boost.
i then noticed the temp go into the red
i got home noticed it was leaking water.
took the center panel off to see where it was coming from.
found a big lump of polestirene jammed between the fan and the rad
now how the hell did this get there,because the front scoop is coverd with mesh (veilside c2 type front ).
cant see no water from front of rad.
need to get car off ground to find out where leak is
hope its not serious
can anyone help ? :cry: :cry: :cry:
From what i can gather, it should still boost when in safety boost, just
no more than 5psi?
As for the polystyrene, do you have the sump guard thing fitted, could've
come through there?
no more than 5psi?
come through there?
dont know never been able to get under the car yet
where do you think the water is coming from
and why should it not boost???
looks like a garage job £££££££ oh shit :cry:
unlucky, mate.. do you want a new zed? just kidding even i wouldnt stoop this low ;) i feel for ya bud! Sounds like its over heated and burst something, could be the rad cap, a hose, headgasket anything really
wheres all the pro,s on here someone must know whats going on
its also started reving around 1500 on idle and when you press clutch
i fitted an apexi intake at billing and it doesnt seem to have been the same since
hi mate your ECU will be ajusting to the new air properties hence reason for slightly high idle give it a couple of hundred miles and should settle :) mines the same since apexi induction kit fitted at billing ;)
maybe a water pipe connected under rad was knocked by the force of something hitting it plus with hoses 10years old tend to perish
have you done an ECU test by lifting up the passenger floor mat undoing bolts and checking for faults via codes maybe a sensor knackered worth a check ;)
hope it aint serious mate greg
what do you need a pro for??? youve got a water leak.. you need to find it....
i can understand the water leak and come the weekend ill find out where its coming from but why should it dip down as if no fuel when i accelerate
Had a waterleak on mine, was a hairline fracture in the sidetank
on the rad....fitted a new rad, problem solved!
hi gregg cheers m8 for the info on the ecu taking time to bed in
hope its nothing serious too
