Safety boost question....
Hi all
My zed went into safety boost again this afternoon.
All was fine until about half way home when I tried to overtake 3 cars :eek:
The last time this happened it was a hot day too and the car wouldn't boost over 7 psi after driving for half an hour.......
Why does this happen?
It is fine early morning when it's still cool
Am I getting det (couldn't hear it?) or is it the sensor wiring?
Any thoughts.......
Richard :(
sounds like det. if it is, switch off then back on again & you should be out of safety boost.
what fuel you using?
dont forget you wont get any codes if its just detected det ;)
Nope - code 34 is if the sensor is outside its range - ie either open or short circuit. If the ECU detects det it will not give any fault codes.
Think about it another way, you don't get a code 13 if the car overheats ;) Code 13 is coolant temp sensor btw lol
