vibration/runmble
I get a bit of a vibration from around 40 mph to around 70 mph (a bit unsure as the speedo keeps packing up (yet to fix(any ideas on the speedo intermittant problem)). Might this be a prop shaft bearing, I'm sure it's not wheel balancing, it seems to be more of a higher frequency :confused: if you get me drift !
Well i know it will be your prop shaft bearing as i have the same symptoms. :eek:
re: your speedo problem, do you have a speedo converter (is your car a jap spec, originally in KM/H and converted to read MPH). If so you may find the converter has gone US, if not your speed sensor could be the culprit.
