carbon fan shroud fitting
has anyone got one of these on if so how do you fitt it??
do you have to drill or bond it on as ive just got mine today
Get a dremmel as it will need a little bit of tweaking and bond it on, silicone sealer does a pretty good job.
dude,
I used a dremmel and took the fins off the shroud........then offerd the CF up to the shroud and it was a distance away when viewed from the back.......
....so I looked to see where the CF was touching the mounts and cut the CF a liitle bit each time until it sat flush on the shroud.
Once I had done that and I was happy, I took it off, added the bonding to the back of the CF and then put it back in place, eased it down into place and let if over night to bond.
:D
Matty.
I actually used some sealant that I had knocking around in the shed, it's solid!!!
It's unibond kitchen sealant (waterproof!) from B&Q.....it works and is solid.
Matty.
