The Plenum is off!
Hi Guys, just this min finished removing the plenum so that i can change this bloody defective Injector(no5)before Billing. After some rather tense moments when the plastic connector broke away, i finally got it out. The end was covered in s#t n muck, alot of which id wiped off before thinkin about putin up some pics
After removing the injector i thought id check the plugs out, as you can see in the pics the plug on the left looks old. When i went to undo it,it was already loose! I had the plugs changed the last time it was at SE Nissan(3 months ago) and i think they mighta forgot to take that one out!!? :eek:
Does anyone know why the plugs electrode would have melted :confused:
(This plug wasnt in the same cylinder as the defective injector)
No posts to show
